bluegill71
Oct 14, 2019Follower
What's best Range extender for Netgear Router C7000v2 ?
What's the best Range Extender for a Nighthawk AC1900 WiFi Cable Modem router with Built -in DOCSIS 3.0 Cable Modem, Model C7000V2. Operating System is WIndows 10 in a Home Environment ?
Oct 15, 2019Guru - Experienced User
Your posting and asking about range extenders in the modem forum, I'd ask this in the extenders forum.
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
The best extender for the c7000 is whatever covers you're needs.
There's a whole range from the ex8000 thats has triband with a band reserved for the wired backhaul and mesh to a simple N300 extender. It comes down to what you're using it for and what you're needs are. You can go to the extenders section on netgear and it'll give you the option to narrow down the selection based upon size, ethernet ports, wifi standards, etc. I'd recommend using this so it narrows it for you to a couple devices and then you can choose from there.
https://www.netgear.com/home/products/networking/wifi-range-extenders/
