TakJ
Dec 08, 2022Follower
When connecting to Wi-Fi with a mobile phone, the message “Log in to the network” appears.
I am using spectrum modem. After purchasing Netgear AC1600 C6250 equipment yesterday The installation was completed, and the setting was also completed through the app. However, when I connect to ...
Dec 08, 2022Guru - Experienced User
The C6250 is a modem/router combo device. It shouldn't be connected to another modem.
So if you're using a spectrum modem as you put in your post, you have it connected wrong and you don't need the C6250.
So how do you actually have it setup?
