iCThruU18
Dec 03, 2022Aspirant
Where is bridge mode? C6300 model
All the instructions that take me to advanced setup to turn on bridge mode Don't seem to apply to this router's settings. I cannot find bridge mode. I have a mesh system which requires me to turn on t...
- Dec 05, 2022
For the most part, double nat's don't cause much for issues. But there's the rare device that does have issues with them. Or people have networked devices can can't access them on both because they're on the 2 different networks.
So if its working fine in a double nat and you don't have issues, then I wouldn't worry about it.
But if you're having issues, then fixing it is one of the first steps.
michaelkenward
Dec 03, 2022Guru - Experienced User
Bridge mode to do what?
That term means different things in different contexts and on different devices. Here's a couple of options
- modem only mode – applies to a modem/router that you want to use as just a modem
- bridge mode to "connect multiple devices wirelessly" – applies only to routers that support this feature
In the case of the C6300 you can forget about the WiFi bridge.
For modem only bridge mode, start here:
How do I set my NETGEAR cable modem router to function as a modem only? | Answer | NETGEAR Support
If, that is, your device supports it.
iCThruU18
I hooked up a mesh system and it says I must put modem router in bridge mode. I saw somewhere that I should go to administration and turn off router mode. This is the same thing as bridge mode. Okay so I did that. Now I can't get back into the router control panel because it's been turned off! How will I ever go in and do anything to the router now that it won't talk to me? And why did I need to put this in bridge mode to use a mesh system? It seemed to be working just fine before I turned off the router mode putting it in bridge mode. They said there could be a conflict but I didn't see one. What do I do now? By the way the mesh system is working just fine...
- michaelkenwardDec 03, 2022Guru - Experienced User
iCThruU18 wrote:
Now I can't get back into the router control panel because it's been turned off! How will I ever go in and do anything to the router now that it won't talk to me?You won't need to get into the router unless things go wrong. There's nothing to control. Unlike my DSL modem/router, you can't even update the firmware on your cable modem/router. ISPs don't allow it.
To get into the thing, disconnect it from the network and plug it into a PC.
And why did I need to put this in bridge mode to use a mesh system? It seemed to be working just fine before I turned off the router mode putting it in bridge mode.Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR SupportWhen to put modem into bridge mode | Answer | NETGEAR Support
- plemansDec 04, 2022Guru - Experienced User
if you disabled the router features on the c6300, you'd need to navigate to 192.168.100.1 to access it.
- iCThruU18Dec 04, 2022AspirantI'm completely rather notice off how do I get in? I am hooked up to the mesh Wi-Fi which is hooked to the modem router by ethernet. When I put in the IP address above it just hangs. I actually called Netgear and they told me I have to reset The whole unit back to factory specs to be able to access it. I'd love to get in without doing that.
- michaelkenwardDec 04, 2022Guru - Experienced User
iCThruU18 wrote:
I'm completely rather notice off how do I get in?You lost me there.
When I put in the IP address above it just hangs.My experience with trying to access a modem/router in modem only (bridge) mode is that it doesn't work as explained in the manuals. Admittedly, I am using a DM200 DSL device, but the approach seems to be the same, just with a different address.
I actually called Netgear and they told me I have to reset The whole unit back to factory specs to be able to access it. I'd love to get in without doing that.Yes, and by resetting everything, you will get access to the modem/router but then get lost with the Mesh network.
Go back to basics. ask yourself what you can do when you access the C6300 after you have put it into bridge mode.
There is nothing to manage. The router is in charge.
If you do want to play around, disconnect everything from the C6300. Connect a PC to its output and try the address you have been advised to use.
In this way, you do not need to reset everything just to play around.
If you want to investigate all this, try reading one of the manuals for a modem only box, like the CM700. Read the section "Log In to the Cable Modem".
As it says there
"After you set up the cable modem, you do not need to log in to the cable modem for normal operation."
