mzd8888
Nov 11, 2015Aspirant
where is the Set Up Access List for Netgear genie v2.01.12
Same problem as ali99asghar, re-posted here again since I did not find any solution yet. Firmware version : v2.01.12 ISP: comcast I have been using the Wireless Card Asscess List for the lon...
hnguye22
Jan 01, 2016Tutor
I have same problem with WNDR3400 V2.
Just happened, after I update the firmware to V1.0.0.52_1.0_81.
DarrenM
Jan 05, 2016Sr. NETGEAR Moderator
hnguye22
Have you tried to use another web browser when accessing the GUI for the modem to see if its still missing?
DarrenM
- hnguye22Jan 06, 2016Tutor
Hello Darren,
I have solved this issue. Just informing you, there is an issue with the latest revision of firmware. After I update, the access list tab is missing from the advance setting.
Many users have the same issue, they complaints. Please remove it from your website or fix the firmware.
Hope this helps,
Hoang
