ksteintrager
Sep 15, 2019Aspirant
Which modem router is best to replace c3700?
I purchased my Netgear c3700 in 2014 and I need to replace it. The square footage it needs to cover is around 3000 sq. ft. I am considering either the c7000 or the c7500. Please advise me on the be...
ksteintrager
Sep 16, 2019Aspirant
What would you recommend? My Netgear c3700 is not working well. I believe it’s lived it’s life.
Sep 16, 2019Guru - Experienced User
So a couple questions.
what speeds are you paying for and wanting? the C3700 is good roughly to 100mbps
How much area are you trying to cover? That and budget is going to be a key points with any router.
What issues are you having? The C3700 isn't the fastest wireless device or faster internet service device but depending on your usage, troubleshooting might not be a bad idea. Especially if its a modem/line issue and not a router issue.
- ksteintragerSep 17, 2019Aspirant
Thanks, I've done all of the troubleshooting and so has my ISP. I've decided to bite the bullet and go with the Orbi mesh system. It's what the layout of my house requires.
- plemansSep 17, 2019Guru - Experienced User
Good luck with the orbi setup. I have an Orbi and appreciate how well it works and how much area it covers.
- FURRYe38Sep 17, 2019Guru - Experienced User
I would go with a CM series modem only unit then connect up your Orbi MESH system. If you want to review the CBK40, this is Orbi with a build in modem. I would recommend getting a modem only unit separately however.
ksteintrager wrote:Thanks, I've done all of the troubleshooting and so has my ISP. I've decided to bite the bullet and go with the Orbi mesh system. It's what the layout of my house requires.
