strykerzr350
Feb 15, 2022Guide
Why am I not getting maxed speeds with my modem?
Recently upgraded to Gigabit Extra with Xfinity and I am not seeing no more than 700 to 800mbps down. Even while testing with a direct connection. My modem signals are within specs and I think I shou...
- Feb 15, 2022
so you're hitting full speeds according to that test.
Feb 15, 2022Guru - Experienced User
A couple things.
1. do you have a screen snip of the cable connections page and event logs?
2. what site are you testing on? Try testing on xfinity's test site. Many test servers can't saturate gigabit. speedtest has gotten better but some of its servers still won't max it out.
3. what device are you testing on?
- strykerzr350Feb 15, 2022Guide
I can post the logs and the signals. I am testing using speedtest, I am testing from my PC which is custom built, with a ASUS motherboard.
https://www.motherboarddb.com/motherboards/1245/Sabertooth/- strykerzr350Feb 15, 2022Guide
My attachments did not work for some odd reason.
- plemansFeb 15, 2022Guru - Experienced User
try testing speeds using xfinity's speedtest site.
