strykerzr350
Feb 15, 2022Guide
Why am I not getting maxed speeds with my modem?
Recently upgraded to Gigabit Extra with Xfinity and I am not seeing no more than 700 to 800mbps down. Even while testing with a direct connection. My modem signals are within specs and I think I shou...
- Feb 15, 2022
so you're hitting full speeds according to that test.
strykerzr350
Feb 15, 2022Guide
I can post the logs and the signals. I am testing using speedtest, I am testing from my PC which is custom built, with a ASUS motherboard.
https://www.motherboarddb.com/motherboards/1245/Sabertooth/
strykerzr350
Feb 15, 2022Guide
My attachments did not work for some odd reason.
- plemansFeb 15, 2022Guru - Experienced User
try testing speeds using xfinity's speedtest site.
- strykerzr350Feb 15, 2022Guide
Netgear has the modem rated at 800 mbps down on their site. Xfinity has it rated at 927 mbps down since it is the CM1000v1 version and I get that its not supported on there anymore, for whatever reason. From what I understood it was because the older chip was expensive, and it had router like features, the new CM1000v2 has those features omitted. With the Xfinity speed test this is what it showed directly connected to the PC. It seems the attachments take a few minutes to show up. Still no over provisoning on the download but the upload it did have it.
Its rated to about 940mbps because it only has a gigabit port.
but I mean test it on here:
