strykerzr350
Feb 15, 2022Guide
Why am I not getting maxed speeds with my modem?
Recently upgraded to Gigabit Extra with Xfinity and I am not seeing no more than 700 to 800mbps down. Even while testing with a direct connection. My modem signals are within specs and I think I shou...
- Feb 15, 2022
so you're hitting full speeds according to that test.
Feb 15, 2022Guru - Experienced User
strykerzr350
Feb 18, 2022Guide
I have updated this as solved. I have also gotten a Netgear CM2000 as Xfinity has delisted the CM1000v1 as being supported by their service. Not even Netgear has the v1 of the CM1000 in their list in the knowledge base. How would I get the full 1.2 gbps speeds to my devices using a 2.5GBE router?
- plemansFeb 18, 2022Guru - Experienced User
Do you have a router with a 2.5gig port?
What router is it?
I'll say you won't notice much (if any) difference going from 940mbps to 1.2gig. I have the same xfinity setup and didn't notice a single change. reason why is most sites/servers won't max out gigabit service so the change to 1.2, didn't really change much of anything.
- strykerzr350Feb 21, 2022Guide
I have a dated Netgear R6400v1 which is on its way out, plus I only get upwards to 400mbps on wireless connections. I was thinking of getting the newer RAXE500 and future proof everything. The R6400v1 does not have the 2.5 port.
- plemansFeb 22, 2022Guru - Experienced User
that'd be quite a jump going froma R6400v1 to a RAXE500.
From a base model device to a flagship device.
- strykerzr350Feb 22, 2022Guide
I know but for some odd reason with the R6400 the speeds to my wired devices are no greater than 300 to 400 mbps. I am using Cat6 cables as well. Might as well get the latest to take advantage of what I am paying for.
