boise
Jan 03, 2021Aspirant
Why does the modem keep dropping over and over again
I bought a Ultra-High Speed Cable Modem(CM1000v2), specifically to replace a a modem that had the Puma chip. That modem would frequently, but randomly, drop service and need a reboot to resume servi...
Jan 03, 2021Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
boise
Jan 06, 2021Aspirant
I have done all of that. Still doesn't work correctly.
- FURRYe38Jan 06, 2021Guru - Experienced User
Are you connecting directly with the modem or is there a wifi router in between?
- boiseJan 06, 2021Aspirant
The modem is connected to the cable internet service. I have a Netgear router connected to the Modem.
What model router is the NG router?
Would need to remove the NG router and see if a wired PC connected to the CM modem directly with out the NG router online to see if the problem still happens.
