boise
Jan 03, 2021Aspirant
Why does the modem keep dropping over and over again
I bought a Ultra-High Speed Cable Modem(CM1000v2), specifically to replace a a modem that had the Puma chip. That modem would frequently, but randomly, drop service and need a reboot to resume servi...
boise
Jan 06, 2021Aspirant
I have done all of that. Still doesn't work correctly.
Jan 06, 2021Guru - Experienced User
Are you connecting directly with the modem or is there a wifi router in between?
- boiseJan 06, 2021Aspirant
The modem is connected to the cable internet service. I have a Netgear router connected to the Modem.
- FURRYe38Jan 06, 2021Guru - Experienced User
What model router is the NG router?
Would need to remove the NG router and see if a wired PC connected to the CM modem directly with out the NG router online to see if the problem still happens.
