Bucket65's avatar
Bucket65
Follower
Nov 15, 2019
Why is donload speed slower from my cable company on 2.4 ghz vs 5 ghz
Model:R6120/AC1200 FirmwRE: 1.0.0.58 My cable company currenlty provides me with a download speed of 80mbps/ upload 6mbps. When I set my phone or other devices to the 5 ghz band I get close to tho...
  • antinode's avatar
    Nov 15, 2019
    > [...] Is there anythingI can do to improve this on my wireless devices
    > that run at teh 2,4 ghz band?
       Replace them with devices which can use the 5GHz band?
       Using the 5GHz band allows higher-speed communication than does using
    the 2.4GHz band.  This is a fundamental feature of the way the IEEE
    802.11 standard is defined.
    > [...] 30mbps [...]
       What are you doing where 30Mb/s is insufficient?
