ABCruz
Aug 25, 2020Follower
Why is it so hard to update Nighthawk C7000V2 firmware and app misdirection?
I have the NIghthawk C7000V2 wifi cable modem router. Firmware is: v1.02.09. My ISP is Spectrum. I downloaded the Android app - Netgear Nighthawk App. As soon as it logs into my router, it say...
GHTYDFER
Oct 26, 2020Initiate
I am having the same problem a run around from both netgear and my ISP if you have figured it out j would love to know. When I tell you our situations are exactly the same I mean im so frustrated with both.
- dwilson6936Oct 26, 2020GuideYes. You were so right. You would think a company that was this big and this Global would fix something so simple as an update or at least give the customer the ability to update their own router since they won’t do it and I SP can’t do it. I even wrote a letter to corporate and of course they never even bothered to respond. Maybe they’ll read this and get it together one day.
- plemansOct 26, 2020Guru - Experienced User
You guys don't understand.
It isn't a "router". its a modem router combo device. It has integrated modem functions which the ISP's control. Its part of the docsis spec. Its not something that netgear can ignore and still expect ISP's to support their devices.You can fully update simple routers or even dsl modem/routers. Just not CABLE modem/routers
You can even now upgrade the CAX80 "router" portion but not the modem as the isp controls that. But it took a significant increase in cpu performance and partitioning to be able to seperate the modem from the router but still keep them integrated. So if you want to "update my router" then either sell your device and buy a modem seperate from the router or buy the cax80.
But complaining because of something netgear doesn't have control of or because you didn't understand what you were getting into when you purchased, doesn't help and isn't going to change things.
- dwilson6936Oct 26, 2020GuideYou see my friend ,that’s the whole point Netgear DID have control over it and so did the customer for years. My router/modem combo is at least three years old and I’ve updated it several times and never had a problem with it until Netgear took that feature away from the customer. Hence all the negative complaining from the customer because they’re not happy about it. 👎🏻I advise people to buy a different brand because I have been very disappointed in not only Netgear Customer Service which is all (overseas by the way )and the fact that I can’t control my router modem combo anymore.
- dwilson6936Oct 26, 2020GuideThe ISP provider told me to wait a month or two and then try to do it again. Maybe it would be approved by then. I haven’t tried it yet but I’m going to try this week. I was able to get my Netgear extender connected to the router though manually so I can have Wi-Fi in my shop. We did find out that there was a problem with the cable line but that was not why the update would not work because we tried to update it after the cable line was replaced and it still did the same thing. But that was about a month or two ago.
