ABCruz
Aug 25, 2020Follower
Why is it so hard to update Nighthawk C7000V2 firmware and app misdirection?
I have the NIghthawk C7000V2 wifi cable modem router. Firmware is: v1.02.09. My ISP is Spectrum. I downloaded the Android app - Netgear Nighthawk App. As soon as it logs into my router, it say...
GHTYDFER
Oct 26, 2020Initiate
I am having the same problem a run around from both netgear and my ISP if you have figured it out j would love to know. When I tell you our situations are exactly the same I mean im so frustrated with both.
dwilson6936
Oct 26, 2020Guide
The ISP provider told me to wait a month or two and then try to do it again. Maybe it would be approved by then. I haven’t tried it yet but I’m going to try this week. I was able to get my Netgear extender connected to the router though manually so I can have Wi-Fi in my shop. We did find out that there was a problem with the cable line but that was not why the update would not work because we tried to update it after the cable line was replaced and it still did the same thing. But that was about a month or two ago.
