ABCruz
Aug 25, 2020Follower
Why is it so hard to update Nighthawk C7000V2 firmware and app misdirection?
I have the NIghthawk C7000V2 wifi cable modem router. Firmware is: v1.02.09. My ISP is Spectrum. I downloaded the Android app - Netgear Nighthawk App. As soon as it logs into my router, it say...
dwilson6936
Oct 26, 2020Guide
You see my friend ,that’s the whole point Netgear DID have control over it and so did the customer for years. My router/modem combo is at least three years old and I’ve updated it several times and never had a problem with it until Netgear took that feature away from the customer. Hence all the negative complaining from the customer because they’re not happy about it. 👎🏻I advise people to buy a different brand because I have been very disappointed in not only Netgear Customer Service which is all (overseas by the way )and the fact that I can’t control my router modem combo anymore.
rnashwenter
Jan 16, 2021Initiate
I will not bother with renduntant statements around Spectrum not pushing the firmware update, by really believe if Netgear is to advertise the Nighthawk app compatibility that they should have engineered this device aligning with said advertising. Simple solution for me - Netgear is getting in back.
- FURRYe38Jan 20, 2021Guru - Experienced User
Good Luck.
