ABCruz
Aug 26, 2020Follower
Why is it so hard to update Nighthawk C7000V2 firmware and app misdirection?
I have the NIghthawk C7000V2 wifi cable modem router. Firmware is: v1.02.09. My ISP is Spectrum. I downloaded the Android app - Netgear Nighthawk App. As soon as it logs into my router, it say...
CrystalsRaegten
Jul 19, 2022Initiate
From what I understand (and I'm not a networking systems guru), the manufacturer is not the issue, so switching to a different company won't help. *All* manufacturers adhering to the "docsis 3.0" cable modem/router standard operate firmware updates the same way. The ISP controls the disseminationn of the updates and work directly with the manufacturer to achieve the appropriate update. The most the user/owner of the modem can do may be click "update" to the current dissemenated version. Once done, you don't even get the that option and it's all automatic and controlled by the ISP.
I've having the same issue, btw. Comcast/Xfinity is claiming they don't have control of firmware updates and recommending that I rent their modem/router.
olympos1625
Jul 26, 2022NETGEAR Employee Retired
Hi @CrystalsRaegten,
Thank you for reaching out. We are sorry to hear about your experience with the modem. We would recommend you ask for the modem department or escalation from your ISP or internet provider. Only ISPs can update the firmware of the cable modem connected to their system and this is true for all manufacturers not just Netgear.
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
