Burty2010
Dec 11, 2015Aspirant
Why is my gateway CG31000-2BPAUS showing partial?i
My gateway modem CG31000-2BPAUS is only partially working, it is from 10 December 2015 out of warranty, do I have to purchase further warranty. Can not find an answer on the NETGEAR site. Also my W...
DarrenM
Dec 14, 2015Sr. NETGEAR Moderator
Hello Burty2010
When you say partially working what are you talking about can you describe the issues you are having with the modem. Hope to hear your feedback.
DarrenM
Burty2010
Dec 22, 2015Aspirant
My broadband connectivity continually drops out, finally disconnecting and providing no internet capability. My IP say the signal reaches my home but the modem appears to be the cause of the dropouts. When viewing Genie my three NETGEAR products are listed with only the modem listed as partially connected, the wifi adapter and wifi extender operation have been discontinued. What do I need to do to remedy the products to be fully operational?
- DarrenMDec 22, 2015Sr. NETGEAR Moderator
Burty2010
I would first check your connections to the modem do you have a cable splitter that is on the cable line attached to the modem I would try to remove that to see if the modem gets better connection. You may also want to do a factory reset on the modem and set everything up again. and if the modem is still having issues you can contact netgear phone support if the modem is still under warranty.
DarrenM
- Burty2010Dec 23, 2015Aspirant
I am going to have an electrician inspect the Telstra connection to the modem. You did not answer my question regarding products out of warranty as I do not intend throwing them out. The modem, extender and adapter are no longer showing up in the Genie display. Why? I may have to research other brands who supply support for their products.
- DarrenMDec 28, 2015Sr. NETGEAR Moderatorburty2010For products out of warranty we do offer gearhead support which I linked or you can always come here for help from the community with the products.DarrenM
