Orion3
Nov 16, 2022Aspirant
Why is my LG TV showing 4 different connections in Access Control?
My LG TV is reporting 4 different connections in the Access Control. One shows the correct MAC Address and the other 3 are weird. One Displays the MAC ID as just 42 the other two are just 8 rand...
Nov 17, 2022Guru - Experienced User
Something to ask the TV mfr about since it there product.
- Orion3Nov 17, 2022Aspirant
But,
if I plug in an amazon plug, the tv connections go back to normal with only one MAC address and then the Amazon plug takes it’s place with 4 different MAC addresses. Come home with my phone, connect to the wifi then the amazon plug goes back to normal, then the phone has 4 different mac addresses.
something about the CAX30 is causing this.
