Raquelmadron
May 09, 2020Tutor
WiFi calling not working with c7800
We have really poor cell service in our house (Verizon) so we rely on wifi calling, especially since I work from home. We got a c7800 modem/router to help with our internet speeds and reliability, but...
- May 14, 2020Update: my Wi-Fi calling stopped working again after about an hour, but started working on my husband's phone. Seemed like only one phone would work at a time. I ended up changing the channel on the router and BAM it's working on all phones now. Guess the channel may have been overloaded. So, if anyone else is having this problem, try Disabling SIP ALG and changing the channel on the router.
May 09, 2020Guru - Experienced User
what specific device are you and the significant other using?
https://www.verizonwireless.com/support/wifi-calling-faqs/
https://www.verizonwireless.com/support/knowledge-base-204165/
https://www.verizonwireless.com/support/wi-fi-calling/
Raquelmadron
May 09, 2020Tutor
I have an iPhone 8 and my husband has an iPhone X. Both worked with WiFi calling before we got this new modem/router last week. We were using a Motorola MG7540 previously.
- plemansMay 09, 2020Guru - Experienced User
try Disable SIP ALG
- RaquelmadronMay 10, 2020TutorDidn't work unfortunately. Any other suggestions?
- plemansMay 10, 2020Guru - Experienced User
Are you using any parental controls, disney circe, armor?
Or Qos? If so, try them disabled.
Also, try connecting the phones to the 5ghz channels and not 2.4ghz.
