LordxWolf
Oct 18, 2018Follower
Wifi Devices Cannot Connect, wifi light are on.
AC32000 Wifi Cable Modem Router model c7800, does allow access via a wireless connection. WIFI lights are on so is the internet. 3 devices connect via hard line work. Also can not apply change any setting on the router via NetGear Genie. Wifi name displays on wireless devices just won't allow the device to connect. Devices say nothing about the connection issue, just won't connect.
1 Reply
- DarrenMSr. NETGEAR Moderator
Have you tried to change the SSID in the web interface? and if it does not allow you to save try another web browser.
DarrenM
