Gdurney
Sep 26, 2021Apprentice
Wifi disconnection
Hello all. For about the past 2 months my modem/router has lost connection/restarted itself every night. The problem has gotten progressively worse as now it does it between 5-10 times a night sometim...
michaelkenward
Sep 27, 2021Guru - Experienced User
Gdurney wrote:
Hello all. For about the past 2 months my modem/router has lost connection/restarted itself every night. The problem has gotten progressively worse as now it does it between 5-10 times a night sometimes. I contacted XFinity who advised they are not having any issues on their end or in my area. I’m curious if this is related to my modem/router?
Sounds likely.
Be warned that ISPs are great at passing the buck. There routine response is "blame the modem".
If you can catch the attention of plemans, they know more than most about cable modems.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Cable Modems & Routers
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Gdurney
Sep 27, 2021Apprentice
I have taken this step and am still having trouble resolving the issue. I have the most recent firmware update, don’t have any splitters, dampeners or any kinks in my line and my modem is only 5 ft. from where the line enters my house.
- GdurneySep 27, 2021ApprenticeAfter much trouble and reading through many other customers posts who have had the same modem and issue as myself, I think I will rent the ISP modem for a month and see if this resolves the issue. That will determine if it is an ISP line issue or Netgear Modem issue. Based on the amount of trouble this model of Netgear modem appears to have my money is on the modem being defective somehow.
