Gdurney
Sep 26, 2021Apprentice
Wifi disconnection
Hello all. For about the past 2 months my modem/router has lost connection/restarted itself every night. The problem has gotten progressively worse as now it does it between 5-10 times a night sometim...
michaelkenward
Sep 27, 2021Guru - Experienced User
Gdurney wrote:
Hello all. For about the past 2 months my modem/router has lost connection/restarted itself every night. The problem has gotten progressively worse as now it does it between 5-10 times a night sometimes. I contacted XFinity who advised they are not having any issues on their end or in my area. I’m curious if this is related to my modem/router?
Sounds likely.
Be warned that ISPs are great at passing the buck. There routine response is "blame the modem".
If you can catch the attention of plemans, they know more than most about cable modems.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Cable Modems & Routers
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Brettmcm
Sep 28, 2021Apprentice
This I can agree with. I printed out the entire manual for my device (AX6 AX 2700 Model CAX30) which is 132 pages long of information I would not otherwise have. After trying and changing every possible concivable problem I am convinced the main problem is the ISP and acutally do to the problem I'm having I'm surprised my device works at all. When I check my cable connection it always shows my ISP address and DNS as 0.0.0.0. I am getting a Dynamic IP adress for them otherwise I would make a static address. My modem/router was activated by them and myself on 3 seperate occasions and now thier app doesn't even give me the option to activate equipment anymore. It's suspcious to say the least. I have noticed that the disconnects come when the device is busy doing something, im guessing trying to obtain an IP and DNS address because of the 0.0.0.0 (or a new device was being scanned by armor). See if you can download the manual and follow the Trouble shooter chapter. My guess is your probably going to see the same thing "0.0.0.0"
- GdurneySep 28, 2021ApprenticeI hope that doesn’t happen but I guess we’ll see. Tonight will be my first test home again to see if my internet shuts off after some of the minor changes I’ve made with the above listed advice. We shall see.
- plemansSep 28, 2021Guru - Experienced User
What changes did you make?
Did you rerun the screen snip of the cable connections page and logs? with as many as you had, we should see shortly how good the connection is.
- GdurneySep 28, 2021ApprenticeI added in a double splitter as that’s what I had on hand. I’ll screen snip the events log and connection page this evening when I’m on the wifi and see what it’s running at and upload it here.
