JLH_2024
May 02, 2024Aspirant
WIFI disconnects intermittently - CAX80
Help!! Wi-Fi is disconnecting constantly throughout the day. My laptop is connected through my company VPN, and my wife's personal PC does not use VPN. Both computers see the same issue with Wi-Fi in...
May 02, 2024Guru - Experienced User
What devices do you have connected to the modem?
Does this happen with wired devices as well?
How is Advanced Wireless settings configured on the modem? Under Advanced Tab/Advanced Settings/Wireless Settings
What channel configurations are currently set on the router?
Any Wi-Fi Neighbors near by? If so, how many?
- JLH_2024May 02, 2024Aspirant
Firmware is 2.1.5.2 - I have checked often to make sure this is current
Roughly 15 devices connected (phones, computers, appliances, security cams, etc)
Does not happen with ethernet connection
No Wi-Fi neighbors nearby
My 2.4ghz Channel is set to auto, 100% power, max speeds
my 5ghz channel is set to ch 36, 100% power, max speeds
- FURRYe38May 02, 2024Guru - Experienced User
Try setting manual channel 1 on 2.4Ghz and 40 on 5Ghz.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-messageHas a factory reset and setup from scratch been performed since last FW update?
- plemansMay 02, 2024Guru - Experienced User
also try setting the 5ghz speed to "up to 2400mbps". At the 4800mbps it needs to use dfs channels and if there's radar/weather in your area, devices have to switch off those channels. if you set it to "up to 2400mbps", you don't need to use the dfs channels.
