capcap203
Apr 05, 2022Tutor
Wifi Extender for Nighthawk AX2700
Hi guys I have the Night Hawk 3.1 AX2700 router/modem. I am using it through xfinity and have speeds around 230 mbps. My garage is about 150 feet away from my modem/router with a couple walls in...
Apr 05, 2022Guru - Experienced User
If you can hardwire in an extender, thats going to give you your best speed. Otherwise you'd want to put it midway between the router and the garage. Netgears AX extenders are the EAX12, EAX15, EAX20, EAX80.
An AC extender would work as well if you're not needing/wanting an AX one. I'd recommend the triband line of those.
capcap203
Apr 08, 2022Tutor
Thank you, I'll be taking a look at those EAX models and see if they seem better than the AC
