kdharlow
Feb 18, 2017Follower
Wi/Fi is unaccessable after hook up with Comcast
Modem is CG3000D
I had set up the modem / router before activating with Comcast.
I logged in to it with http://192.168.0.1, use admin and password to log in,
changed password for log in.
set wireless speed to what i wanted.
named wireless network.
set up new password for wireless network.
tested wireless network before activating with Comcast.
After activating with Comcast, lost access to wireless on modem / router.
Cannot log into router now with http://192.168.0.1, just get an error.
short of resetting router, any suggestions??
i haven't bean able to find correct connection link
- osama02Aspirant
i'm having the same issue. cannot get wifi to work. would be great if someone could answer this. will have to return the device if not corrected by tonight.
- DarrenMSr. NETGEAR Moderator
Did you check to see if the gateway Ip address changed after they activated the modem?
DarrenM
- osama02AspirantIt shows as 10.1.10.1 but no wifi settings in there
Hello osama02
Sounds like something is wrong with the boot file causing the modem to be a modem only and disable the router functions. You may want to check with Comcast internet support the coding of your account if it is correct for your modem.
DarrenM
