Wariat
Aug 15, 2019Aspirant
WiFi is very slow on 2.4Ghz
Speed test on my Wifi show between 2 and 8 Mbps on our phones/tablets, on my laptop I can't even get it to conduct a test, the interent is barely usable. Power cycling has not helped. My Xfinity acco...
Aug 15, 2019Guru - Experienced User
Has a factory reset and setup from scratch been performed on the modem?
Use a wired Pc and speed test with Ooklas installable speedtest app.
Be sure no coax cable line splitters are in between the ISP service box and modem.
Wariat
With a wired connection, using the Ookla software, the latest test reached 275Mbps, which is great. I have not tried a factory reset... I suppose that a factory reset is the next step...
