rvint
Jul 18, 2024Aspirant
Wifi no internet C7000 v2
Hello- Wifi was working last evening and no connection this morning. I have power cycled several times as well as hard reset 3 times. My desktop is hard wire connected and has internet. I can connec...
- Jul 19, 2024
Working- Thanks!
Jul 18, 2024Guru - Experienced User
Does using the erase button the modems web page with the wired PC and setup from scratch change anything?
https://kb.netgear.com/24233/How-do-I-erase-the-configuration-settings-on-my-Nighthawk-router
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
rvint
Thanks for the thought.
I did do a hard reset with no luck. I will try erase, power off overnight and try fresh in the morning.
- FURRYe38Jul 18, 2024Guru - Experienced User
- rvintJul 19, 2024Aspirant
Working- Thanks!
- FURRYe38Jul 19, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
