rvint
Jul 18, 2024Aspirant
Wifi no internet C7000 v2
Hello- Wifi was working last evening and no connection this morning. I have power cycled several times as well as hard reset 3 times. My desktop is hard wire connected and has internet. I can connec...
- Jul 19, 2024
Working- Thanks!
rvint
Thanks for the thought.
I did do a hard reset with no luck. I will try erase, power off overnight and try fresh in the morning.
Jul 18, 2024Guru - Experienced User
- rvintJul 19, 2024Aspirant
Working- Thanks!
- FURRYe38Jul 19, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
