VALLOTB
Sep 05, 2019Follower
wifi password change
I need to change the password for my modem. please, a simple answer.
antinode
Sep 05, 2019Guru
> I need to change the password for my modem. [...]
Why? Which "the password"?
> Model: CM500|16x4 DOCSIS 3.0 Cable Modem
Is that your "my modem"?
A CM500 is a modem, not a (wireless) router, and, as a modem, it has
nothing to do with any "wifi password".
> [...] please, a simple answer.
Please, a clear explanation of the problem which you are trying to
solve.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read.
