jaxmax62's avatar
jaxmax62
WIFI Please help with uninstall and reinstall C7800 Nighthawk X4S
  • At the back there's a Reset button. Press it for 10 seconds or more then release. That will wipe out all settings and revert to factory default. Now you can go on to configure or "install" it.
  • michaelkenward's avatar
    michaelkenward
    Can't tell what the problem is from that message.
    When you have read the message from microchip8 consult the manual.
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
      michaelkenward
      We still don't know what your real problem is and why you mentioned wifi in the subject.
