wifiman03
Apr 14, 2019Follower
Wifi problem
I’ve had this router for about a year now. About 2 weeks ago my wifi was bad so i went to un plug it for about 10 seconds. When it turned back on it didn’t connect me right away which was strange. I w...
michaelkenward
Apr 15, 2019Guru - Experienced User
Your footer says you have the C6900. You have posted your message in the section of this community given over to General WiFi Routers (Non-Nighthawk). (This is easily done, given Netgear's impenetrable community structure.) Your device is a Cable Modem/Router.
You might get better replies, and find other answers, over in the appropriate section:
Cable Modems & Routers
There is support for the C6900, including a manual, at the end of this link:
>>>C6900 | Product | Support | NETGEAR<<<
