RonanC
Jan 23, 2019Aspirant
WiFi range
I have a CM500V and a netgear wifi extender. Both are within ten metres of each other yet the wifi signal is still poor. The router light is also red (at times). Any suggestions on how to improve ...
Nodism1125
Jan 24, 2019NETGEAR Expert
Hi RomanC,
CM500V is a cable modem only.
Do you have a wireless router to extend the wireless signal?
What is the product model of the Wifi Extender?
- RonanCJan 24, 2019Aspirant
Hi, ,I am using a NetGear AC750 WiFi Extender. Thanks in advance for your help.
R - RonanCJan 24, 2019Aspirant
Hi, the wifi router is a sagemcom Gateway F@st
- Nodism1125Jan 25, 2019NETGEAR Expert
Hi RonanC,
You need to access the Extender GUI and check the configuration since you have a poor connection to the gateway router.
https://kb.netgear.com/30997/How-to-configure-your-NETGEAR-Range-Extender-EX7300-using-the-Web-GUI
