Jcmaier
May 27, 2017Aspirant
Wifi single dropping
My wifi single keeps dropping but my internet connection doesn't. I've rebooted, reset. I've had my cable checked. My ISP has come out to my house. I've changed channels. I've had this C6300 modem/...
DarrenM
May 31, 2017Sr. NETGEAR Moderator
Hello Jcmaier
Do you notice it dropping during certain times or when using a certain device or is it just random?
DarrenM
Jcmaier
May 31, 2017Aspirant
It was random. I'd try to note the time of day but no consistency.
- DarrenMMay 31, 2017Sr. NETGEAR Moderator
Hello Jcmaier
I have 2 things I could suggest trying the first one is try lowering the power level of the 2.4 ghz network you can find this in Advanced-Advanced setup-wireless settings then lower the transmit power control I have seen this fix wifi disconnect on other routers before. Or you could try to factory reset the modem and set it back up again in case of something strange that may of changed in your router.
DarrenM
- JcmaierMay 31, 2017Aspirant
Thank you for the suggestion. I'll try and post later.
