RangerDanger
Jan 07, 2020Aspirant
WIFI Speeds C7800 capping out around 200mbps
Hello, I recently purchased the Nighthawk X4S-AC3200 cable modem router from Amazon.com as an upgrade for my xfinity internet service. I am subscribed to the 1000mbps plan. I understand that wifi...
Jan 08, 2020Guru - Experienced User
I currently have my PC, PS4 and Phone connected to the 5ghz connection. Using speakeasy, comcast and any other speed test website I could find online I have got between 150 and 205 top speed. I have tried changing channles to ones not being used by other networks around me and called Netgear support who only had that one suggestion for me after nearly an hour on the phone.
My PC network card is an Intel Dual Band wireless - AC 3165, when I looked this up it says its max speeds is around 400mbps. I purchased a wireless dongle adapter from amazon that has also not helped.
https://www.amazon.com/gp/product/B07FGX8LBF/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
Any suggerstions would be greatly appreciated. Thank you!
The intel AC3165 is a 1x1 antenna solution. Its max connection speed is 433mbps. And like duckware said, thats the PHY speed. It'll never hit that. Realistic speeds based on PHY are around 50%. So hitting 200 is roughly in line with whats expected from that wifi card.
What speeds did you hit with your USB wifi card? Is it plugged into a usb 3.0 port or usb 2.0 port on your pc?
RangerDanger
Jan 09, 2020Aspirant
I have it plugged into a blue 3.0 USB port. I deactivated my intel card and am still only getting around 200, 210 being tops a couple times. It shows 100 percent signal strength. From what I can find I have the latest firmware update installed on the router, even at the 50 percent expectation wouldn't you think I should be seeing faster speeds thru the USB?
- plemansJan 09, 2020Guru - Experienced User
RangerDanger wrote:I have it plugged into a blue 3.0 USB port. I deactivated my intel card and am still only getting around 200, 210 being tops a couple times. It shows 100 percent signal strength. From what I can find I have the latest firmware update installed on the router, even at the 50 percent expectation wouldn't you think I should be seeing faster speeds thru the USB?
do you have another device you can test with other than this laptop? maybe its an issue with the laptop.
- RangerDangerJan 09, 2020AspirantI have a mini PC with the following listed as the WiFi adapter on amazon WIFI: IEEE 802.11a/b/g/n,2.4G+5.8G. I am maxing out at the same speeds on it very close to the router, perhaps 10 feet clear shot, i have also tested in my iPhone 6plue with the same results.
- plemansJan 10, 2020Guru - Experienced User
Wifi is tough to test with because so much depends on the devices you're using.
Even the iphone that your testing with the 6 plus, testing showed that it routinely hits MAX speed of 280mbps because it was first generation wireless ac. (this is all from research as I don't have a 6 plus)
I know you think you're wifi isn't doing what it should but you're either testing with older equipment, single antenna solutions, or usb solutions thats reliant on the usb bus.
I've actually used a c7800 for a while and could routinely hit 400-500mbps on a gigabit plan over wireless. But this was using an intel 9260 or Samsung s9.
so I'm not sure what to tell you. You can try factory resetting and starting over. You could also try borrowing someone's laptop/phone that is a newer device to see if even the newer equipment is limited.
