Alisiag75
Jun 27, 2022Aspirant
WiFi won't connect
My WiFi light is on, and I can connect to my laptop remotely, but nothing else will connect. Tried to go to the Nighthawk app on my Iphone, but it says I have to be connected to the network to fix t...
Jun 27, 2022Guru - Experienced User
Try to disable WiFi Private Address on the iphone:
Make sure Local Network for NH app is enabled:
Try a factory reset on the modem and setup from scratch using a wired PC and web browser.
