flinky
Jul 16, 2021Guide
Win10 Reports C7000 has connection issues/problems
I bought my Nighthawk C7000 just over 2 years ago and have rarely had a problem, other than not getting very good WiFi range in an apartment with relatively thicker plaster and metal lathe walls....
- Oct 22, 2021
I've solved the problem and I will figure out the nature of keeping the extender/bridge assigned in the proper IP range.. On occasion I'd turn on an Asus Asus RT-AC88U router/extender set in extender mode to reach weak spots. It's a fantastic device and connected to the c7000 via ethernet. For some reason the c7000 began to assign it 192.168.1.1 (perhaps the extender reset) and , for reasons I cannot explain, the c7000 decided to occasionally provision wireless devices under the 192.168.1.x IP address format rather than just drawing from the DHCP server. One mobile device might connect but the Pixel just could not. Shutting off the extender and rebooting the phone now seems to connect the phone to the router.
I couldn't understand this as this setup worked so well until recently. Hopefully now we can fix this and move on. Thank you all for your prior help.
flinky
Oct 21, 2021Guide
Thanks and sorry for the late reply. I didn't get an email there was one. I am still having serious problems as now WiFi does not show as provisining and all phones get "no internet access". After about a year and a half, these problems began out of nowhere and persisted.
- performed a hard reset and that worked better for a few days, at best, before the problems began again
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
- Checked
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
- None and, if there is one or an extender, it was installed by my cable company
Be sure your using good quality RG6 coax cable up to the modem.
- Runs straight from the wire to the modem
Be sure to power OFF the modem for 1 minute them back ON.
- I've not only done this, I've also done a hard reset too
flinky
Oct 21, 2021Guide
Looks like I will need to buy another expensive modem router I don't need. I doubt warranty support extends beyond 1 year but I couldn't register or contact support anyway - the website says "Sorry! It's us not you!" when I've clicked on checking warranty support, register a product, or technical support to contact Netgear.
Unfortunately I'm also constantly going to Windows 10 and using ipconfig to release and renew the IP configuration on the router and that I can't get the mobile devices to connect properly is troubling. Seems that once I start approaching more than 13, 14 wireless devices things don't function. It's also not a great sign when being literally 6 feet from the router provides noticeably less signal strength than someone else using a Google wireless router that is a thick ceiling away from me, if not further and in another room on another floor.
While the c7000 performed very solidly for a year, it's extremely disappointing that towards the middle of year 2 it is already ready for retirement and resulting in a poor investement. I do hope that there is some remedy for this as I cannot afford to be without consistent internet services. Thanks.
- FURRYe38Oct 21, 2021Guru - Experienced User
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 or 149 to 161 channel on 5Ghz.
Try enabling any Beamforming and MIMO(MIMO may or may not be needed) and WMM features that may be seen. Under Advanced Tab/Advanced Settings/Wireless SettingsWhen this happens does both wireless and wired devices have problems getting internet access?
