fullbright
Jun 27, 2022Aspirant
wired readyshare
Can't turn off readyshare on my Nighthawk AC1900 WIFI Cable Modem Router The network map shows there is a wired computer as readyshare connected to the router. I just let my own devices to connect t...
Jun 27, 2022Guru - Experienced User
Can you post a screen capture of this Readyshare page on the modem?
Try a factory reset and setup from scratch with a wired PC and web browser.
- fullbrightJun 27, 2022Aspirant
This is the screenshot from the attached devices.
There were many other posts (for example: "Unknown device connected to wifi" from 2018; "N600 Model C3700 ReadyShare - Does is show on my network as a linex computer? from 2018; " C3700-100NAS ReadyShare - Disable This Feature" from 2020) related to this issue. Apparently there is no a clear solution suggested.
- FURRYe38Jun 27, 2022Guru - Experienced User
Are there any options on the ReadyShare page on the modem that you can select or this just shows whats connected?
