fullbright
Jun 27, 2022Aspirant
wired readyshare
Can't turn off readyshare on my Nighthawk AC1900 WIFI Cable Modem Router The network map shows there is a wired computer as readyshare connected to the router. I just let my own devices to connect t...
Jun 27, 2022Guru - Experienced User
Are there any options on the ReadyShare page on the modem that you can select or this just shows whats connected?
fullbright
Jun 28, 2022Aspirant
Only shows "Basic" chosen.
I also tried the suggestion given in the post (C3700-100NAS ReadyShare - Disable This Feature" from 2020). Initially it disappeared from the list but then it came back after some time.
- fullbrightJul 01, 2022Aspirant
so any suggestions?
