JWY-Leucadia
Apr 15, 2020Tutor
Wired Router for CM1200
Does Netgear make a WIRED (not WiFi) router that works with the CM1200? If not, can anyone recommend another brand & model? I already have an Orbi WiFi router but for various reasons it can't be lo...
- Apr 15, 2020
Sorry I surely didn't look closer are your question.
Not that I can tell:
https://store.netgear.com/home/?lang=en_US&_ga=2.37360672.1499443964.1586975252-197904915.1586975252
Most routers include wifi now days. Most R, XR and RAX series routers have built in wifi radios that can be disabled if wifi isn't needed.
Other suggestion would be to maybe go with wired FIREWALL appliance device. These have some router features and good for firewall and usually don't have wifi radios built in.
Or go with Ubiquity routers. Edge X router doesn't have wifi. Wired only. I have one.
Apr 15, 2020Guru - Experienced User
NG Orbi MESH, R, XR or RAX series routers all work with the CM modem. Just pick something that best suites your needs.
- JWY-LeucadiaApr 15, 2020Tutor
Thanks FURRYe38 but aren't all of these WiFi routers? I'm specifically looking for a WIRED router.
- FURRYe38Apr 15, 2020Guru - Experienced User
- plemansApr 15, 2020Guru - Experienced User
I've heard good things about the edge router's but haven't tried one yet. It'd be a good route to go if you're looking for one without wifi.
