JWY-Leucadia's avatar
Apr 15, 2020
Wired Router for CM1200
Does Netgear make a WIRED (not WiFi) router that works with the CM1200?  If not, can anyone recommend another brand & model?  I already have an Orbi WiFi router but for various reasons it can't be lo...
  • FURRYe38's avatar
    Sorry I surely didn't look closer are your question.
    Not that I can tell:
    https://store.netgear.com/home/?lang=en_US&_ga=2.37360672.1499443964.1586975252-197904915.1586975252
    Most routers include wifi now days. Most R, XR and RAX series routers have built in wifi radios that can be disabled if wifi isn't needed.
    Other suggestion would be to maybe go with wired FIREWALL appliance device. These have some router features and good for firewall and usually don't have wifi radios built in.
    Or go with Ubiquity routers. Edge X router doesn't have wifi. Wired only. I have one.
