Derrick1
Mar 13, 2009Follower
Wireless cable modem gateway CG814GCMR
Hello, I am having lots of problems and I dont know where to put this post because I saw no where to put this one.. 1. I need to update my firmware and I cannot find one at all for this, also there...
jmizoguchi
Jul 07, 2014Virtuoso
Yea the ISP told me to contact netgear cause everything is fine on their end so they say but I think since they have firmware installed on it that says docsis 3.0
DOCSIS3.0 is not firmware.
Here is some you can learn
http://en.wikipedia.org/wiki/DOCSIS
that it is the wrong firmware and it is messing with a few programs that before I got this modem worked fine together
ISP can push the firmware so that is what happen. This is old unit so possible you need to get your unit replace to more updates unit. .I would consult your ISP for upgrade
