jm5
Apr 02, 2020Aspirant
Wireless Gateway losing download speed
I have 30M download speed service from Comcast. My Cable Router is only 4 months old. For the last couple of weeks, I've tested my download speed at around 3M. I've power-cycled my Cable Modem twi...
Apr 03, 2020Guru - Experienced User
Take a screen snip of your modem's connetion page and post it here. It shows the connection back to your isp. I'll link to an example of what I'm looking for.
What speeds do you get hardwired into the C6300?
Any splitters, amplifiers, attenuators in the coax line? if so remove them
Preferably, move the C6300 to right where the coax enters the home. this prevents wiring within the home from being the issue.
jm5
Apr 03, 2020Aspirant
Not understanding your png diagram. If it is a connection issue, still wondering why I would get full speed after power-cycling my cable modem router
