jackbmc
May 26, 2017Tutor
Wireless LED blinks some but Power Light is Solid
Even though my POWER Light is solid my Wireless light (very bottom LED) will BLINK ever few seconds but erratically. Should not the wireless light always be sollid? The 2.4g and 5g blink and that is expected. But the WIRELESS LED?
Please give me your thoughts.
Thanks!
I am moving this to the Nighthawk forum (C7000).
This might explain it: https://kb.netgear.com/24603/How-do-I-disable-enable-the-LED-lights-on-my-Nighthawk-router
- jackbmcTutor
Thanks for point out the discussion on blinking lights. And for moving my query to the Nighthawk forum. However, as the screen shot shows, I don't have a tab under Advanced that allows me to change the LEDs. Apparently, they are set now to blink when data is received...that's fine. However, my question relates to the primary WIRELESS LED at the bottom...not the 2.4g or 5g.
Are you saying that the primary WIRELESS LED wil blink when data is recieved? If so, I am getting little data even though the 2.4g and 5g are blinking far more refrequently.
