BrianRi
Dec 29, 2015Follower
Wireless-N 150 Router WNR1000 v2
I am wondering whether I have redundancy in my home setup. I have two Netgear routed connected, #1 is a Netgear Wireless-N 150 Router WNR1000 v2 and #2 is a Netgear Wireless-G Router WGR614 v9. The ...
DarrenM
Dec 30, 2015Sr. NETGEAR Moderator
Hello BruanRi
You dont need both routers unless the coverage in your home is bad and the 2nd router is a good distance away from the first one but if you need both all you need to do is log into the the WGR614 v9. then got to LAN IP setup and uncheck Use router as DHCP server.
DarrenM
