bmayrand
Nov 07, 2022Aspirant
Wireless password changes back to default when I reboot the CAX30 router
When I reboot my router or it reboots after a power outage, the WiFi password reverts back to the default factory password. How do I maintain the WiFi password I entered for my network? Thanks
bmayrand
Nov 15, 2022Aspirant
I'm using the latest version of firmware for this router. On the cable modem router, you can not update the version yourself. This is done be the Internet provider. I still have not figured out why the WiFi password reverts back to the default password when the router is rebooted. Thanks
Nov 15, 2022Guru - Experienced User
The router portion of the CAX30 can be FW updated by users. Only the modem portion can't be updated on the CAX30.
