EyeSpy
Nov 15, 2016Tutor
Wireless signal can't be found on some devices - C6300
Out of nowhere on an older computer (5 years), I am not able to find wireless signal from the C6300. I can find signals on other wireless in the neighborhood on the older computer. I can find the w...
- Nov 21, 2016
My patience ended.... I purchased the exact same netgear product this weekend after losing hours trying to fix the old one.... along with not having access to some of my devices. I wanted installation simplicity (the old one worked great when it worked) so I elected to get the same model.
I installed the new product and everything is working great! The old modem/router was defective, although told otherwise by Netgear support. I boxed up the old one and sent it back. Disappointing experience. Glad to have all my devices working again.
blitzkrieg917
Nov 16, 2016Aspirant
hi
all the sudden i too am having issues with my 2.4 wifi, the light on router is not lit, but when i login to the router, it says both 2.4 and 5 are working /enabled
EyeSpy
Nov 16, 2016Tutor
Exactly. I have a support ticket open which I plan to followup on tonite. I will advise of the outcome.
