TxAggie's avatar
TxAggie
Guide
Jun 05, 2017
Wireless speed is slow, especially at night, what's going on?!
Hi All - Total wifi/router NOOB here.   Problem I've been having is that on my normal wifi (not the 5G*this setting works great) I'm getting speeds of less than 10 mbps and at night it can be less ...
  • TxAggie's avatar
    TxAggie
    Jun 12, 2017
    Just thought I'd follow up on this for those that were curious. I had tested my speed directly through ethernet at the modem/router combo and was getting the full 100 mbps that I was paying for. Unfortunately, I was not getting this out of my 2.4 ghz connection wirelessly (it was going in and out somewhere between 1-40 mbps). I was advised by help desk to change the channel via router login to get off a channel that others were using. This temporarily helped, but still the problem persisted. I called back again and we did a reset of the equipment that seemed to again temporarily help (maybe 2 days). After both of these things were tried they noted that my unit was to blame and they would be sending me a replacement. Hope this helps for those in the future. Also was unsure of how to handle this since I did not buy the telephone service contract this is SUPER EXPENSIVE...despite me having a 1 year warranty on the equipment. I made the point with out could I convince them that I needed a replacement if they wouldn't at least test to see if it was working properly. Seemed to work.... At any rate.. new device being shipped to me now.
