TxAggie
Jun 05, 2017Guide
Wireless speed is slow, especially at night, what's going on?!
Hi All - Total wifi/router NOOB here. Problem I've been having is that on my normal wifi (not the 5G*this setting works great) I'm getting speeds of less than 10 mbps and at night it can be less ...
- Jun 12, 2017
Just thought I'd follow up on this for those that were curious. I had tested my speed directly through ethernet at the modem/router combo and was getting the full 100 mbps that I was paying for. Unfortunately, I was not getting this out of my 2.4 ghz connection wirelessly (it was going in and out somewhere between 1-40 mbps). I was advised by help desk to change the channel via router login to get off a channel that others were using. This temporarily helped, but still the problem persisted. I called back again and we did a reset of the equipment that seemed to again temporarily help (maybe 2 days). After both of these things were tried they noted that my unit was to blame and they would be sending me a replacement. Hope this helps for those in the future. Also was unsure of how to handle this since I did not buy the telephone service contract this is SUPER EXPENSIVE...despite me having a 1 year warranty on the equipment. I made the point with out could I convince them that I needed a replacement if they wouldn't at least test to see if it was working properly. Seemed to work.... At any rate.. new device being shipped to me now.
DarrenM
Jun 07, 2017Sr. NETGEAR Moderator
Hello TxAggie
It does sound like some type of interference are you testing the wifi speeds on one device or multiple?
DarrenM
TxAggie
Jun 12, 2017Guide
