kailajune
Mar 27, 2019Follower
Wireless vpn connection drops
I have had my AC1900 Nighthawk Cable Modem Router for 6 months with my current vpn Cicso AnyConnect without issue.
About one month ago I started having occassional dropped Skype calls and wireless drops. Now I cannot even stay connected for 10 minutes. My company tech support has done many diagnostics and says it must be a firewall change with Netgear.
I am not able to update my firmware for this model because Netgear does not have it available.
I have tried every wireless setting that I can find to play with (internet search rabbit hole).
Ideas? Or do I need to buy new equipment?
1 Reply
- DarrenMSr. NETGEAR Moderator
Are you seeing any T3 or T4 timeouts in your cable logs? Also are you able to post the power levels of your modem?
DarenM
