Prashantdogra
Aug 30, 2016Aspirant
Wireless working but not wired model :c3000
Hi,    My 'netgear N300 wifi cable modem router' is working for wiresless but the ethernet suddenly stopped working. I have two ethernet ports on modem/router and tried both of them. None works. The e...
DarrenM
Sep 01, 2016Sr. NETGEAR Moderator
Hello Prashantdogra
You may want to check your etherenet cords make sure those are good then you might want to try a factory reset on the modem. When you factory reset you will have to setup all the settings on the modem again. If the ports are still not working I would contact Netgear support if your modem is still under warranty.
https://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
