Prashantdogra
Aug 30, 2016Aspirant
Wireless working but not wired model :c3000
Hi,    My 'netgear N300 wifi cable modem router' is working for wiresless but the ethernet suddenly stopped working. I have two ethernet ports on modem/router and tried both of them. None works. The e...
Prashantdogra
Sep 01, 2016Aspirant
Thanks Darren. I checked ethernet cords.. Tried with new ones as well. I dont think thats an issue. Do you know how to do factory reset? I tried switching off, taking wires off, holding for dew mins and then conencting again.
- DarrenMSep 01, 2016Sr. NETGEAR ModeratorHello Prashantfogra You will have to hold down the reset button for 10 seconds which is a pinhole on the back of the modem that will factory reset the modem. DarrenM
